fetching emails from google seems to repeat/get stuck
yes, so the title gives the question.
when I start the thunderbird app on windows 10 laptop it starts to fetch 2000+ emails from google. Everytime even after letting it go through the process.
Its super slow and always reports its stuck at 2 out of 2000+ emails. Very strange.
I have let it run for 24 hours+ on one occation to get everything loaded. The loading status bar disappeared but it restarts everytime I open the app again.
Any idea why?
Best regards,
Oskar
yes, so the title gives the question. when I start the thunderbird app on windows 10 laptop it starts to fetch 2000+ emails from google. Everytime even after letting it go through the process. Its super slow and always reports its stuck at 2 out of 2000+ emails. Very strange. I have let it run for 24 hours+ on one occation to get everything loaded. The loading status bar disappeared but it restarts everytime I open the app again. Any idea why? Best regards, Oskar
Nseta ihuenyo ndị agbakwunyere
Google does rate limit. But that doesn't sound like your issue.
Please try the followoing:
Does problem change?
Wayne Mery said
Google does rate limit. But that doesn't sound like your issue. Please try the followoing: Does problem change?
Hi,
thanks for the testing tip.
Indeed just starting the app in troubleshoot mode changes the behaviour = seems to not load any extra or get stuck. Just some short checks on all the emailaccounts and then its done. As expected.
Reinstall the app or what should I do?
Jụọ ajụjụ
